I want to implement a report of list of tag numbers are simulated or a list of tag numbers that have pv_bad alarm.
how can I implemet such reports?
We had an issue with emails going out, so I'm bumping some of the threads so that track members can see your question.
You can do it in "Process History View".
Use proper filters.
I agree with Roman - for basic reporting functionality just select the filtering criteria in PHV and save the PHV file so that you can recall that configuration/query again. If you want to be able to pull it up from a DeltaV graphic, then you can create a file link on the graphic to call up that specific PHV file. I'm sure there are probably other ways as well.
