How to get some reports from deltav?
I want to implement a report of list of  tag numbers are simulated or a list of tag numbers that have pv_bad alarm.
how can I implemet such reports?
  • We had an issue with emails going out, so I'm bumping some of the threads so that track members can see your question.
  • You can do it in "Process History View".
    Use proper filters.
  • I agree with Roman -  for basic reporting functionality just select the filtering criteria in PHV and save the PHV file so that you can recall that configuration/query again.  If you want to be able to pull it up from a DeltaV graphic, then you can create a file link on the graphic to call up that specific PHV file.  I'm sure there are probably other ways as well.
