I have a new Bihl-Wiedemann BWU3851 that I am trying to connect to an EIOC. I believe that I have the ASi Gateway setup correctly with the correct EtherNet/IP address.
But I am still not able to see it in diagnostics.
I am not sure how the Logical Device Properties should be setup.
My current settings are
message class: Class 1 Implicit
Connection Priority: Scheduled
ms:400
Connection type: Point to Point
In bytes:32
Out bytes:32
In Assembly Instance: 1
Output Assembly Instance: 2
Config Assembly Instance: 6
Do these look correct? (These worked for an AB PF 755 VFD, but I am not sure if they would be the same or not.)
Thank you for the help.
en_manual_ethernet-ip (1).pdf
