Hello I was hoping for some guidance on the following problem.
We have a device that we are reading alarms from. Currently there is a 16 bit going into a BFO block and each bit represents an alarm status.
Unfortunately when our machine goes into alarm or crashes there are multiple faults coming in at once and we are looking to track these just to get an idea of if something is starting to fail in a particular way. We have 6 of these set up within the same control module and would ideally like to keep it all together if possible.
Somethings we have tried are using the log event triggered by each bit but we hit the max number of blocks in a control module. The issue I keep coming across is logging each event when there are multiple coming in at once in the same block. I am still learning quite a bit with DeltaV so I may just be missing some other way to accomplish this.
