Hello,I would like to add a newline character to a message box message.Tried using the \n as seen below.
I can get it to work with the alert function
But with the message box, it is just adding a space.Is there some other special character to be used for a message box?
Regards,Navin Singh
In reply to Matt Stoner:
In reply to Navin Singh:
Hi Navin,
Have you considered using a small Contextual Display for Message Box alternative?
It would be possible to configure multiple context parameters that can populate the message box when called from the interface. This is a potential solution:
In Graphics Studio add an interaction to Open a Contextual Display to the desired object
Create a simple contextual display like this, notice it is small and the Window Title is linked to a Context Property (Context1) from the previous screen capture.
The text box in the contextual display has a couple of configuration changes:
1. Uncheck the Lock Height to Font Size box and stretch down to fit your needs
2. In the Text tab, check the Wrap Text check box and consider using a "newline sequence" to indicate where to inject the new line, in the case you want to use the "Message:" header I show here for illustration purposes. Also Add a Placeholder that will be linked to the Context property (Context2). It is possible to just add the placeholder and no heading "Message:" or newline sequence would be needed.
For the button to close the message, assign DL.PopupClose() to its action script
In runtime, these changes will look like this:
Another advantage of Contextual Displays is that they are not Modal and there is no gray out effect behind them.
Camilo
Camilo Fadul | DeltaV Solution Marketing Director
https://www.linkedin.com/in/cfadul
In reply to Camilo Fadul:
Hello Camilo,
Thanks for the detailed explanation with illustration.
I am able to create a popup window with multiple lines.
However, the issue I have is my message is variable I can’t hard code the message offline.
This results in part of the message being truncated as seen below, the module name FIC-1 is not visible.
I understand that in DeltaV Live we cannot resize the window in runtime.
By using the standard message box the window would resize itself.
I will remember the solution provided by you in case I have to display a static message with multiple lines.
