I am facing problem,
I need to write few variables into DeltaV. My APPL came with 250 OPC licenses. When I run OPCwatchit on the APPL I don't see OPC.DELTAV.1 server on the APPL. But when I run OPCWhatchit on the Pro+ and change server to APPL, I can access data. 1. question is: Why I cannot access OPC server locally on the APPL? Is it necessary to be loged using deltaV logon or is it enough to be loged with windows user. I am asking because I am connecting remotely and after connect into th APPL I can see the information that "Deltav autologon didnt occure because there is no remote session"
On this APPL there is running OPC Mirror which transfer data from SERVER2 into APPL. So OPC Mirror also can access OPC server on the APPL.
2.question: May I use some another program to access OPC server? Limitation are only amount of communicated variables (in this case 250)? I don't want to buy another licenses for OPC mirror only because of few variables.
Thank you for any help
