Hi Guys,
How do behave phase parameter if a phase normal end. I guess the values and even the memory get destroyed because a non running phase show all phase parameter as undefined/unresolved.
Is this so correct or will the phase parameter hold the last value after normal phase end somewhere and destroy the variables only if the phase is unloaded?
Discussion comes up if phase parameter should reset to a default at phase end.
Thank You and Best Regards,
Michael
In reply to Matt Stoner:
