Hi all,
I have a BFI which has multiple inputs connected to the inside of the fan the OUT is not passing the value to the parameter connected to an external reference but is passing the number/value to an internal parameter, can anyone advise as to what the issue maybe?
This external parameter is used to pass data to an S7-1500 CPU, the map for the data is correct as all the references are showing good, we are receiving values in from the PLC via a BFO so we know the comms is working.
any help of places to look would be appreciated.
