You can now opt for Rosemount wireless 2051/3051 as alternative of pressure gauge replacement to reduce your operator round trips to check pressure reading manually. Reducing operator round is equal to improve productivity and also increase safety by reducing risk of exposure to hazardous gases and bad weather (read more).
How about if you would like to use Rosemount Wireless 2051/3051 as battery powered gauges without gateway ? You can disable the network searching function of the transmitter thus it won't attempt to join to network. Disabling network searching function means also conserving transmitter battery so it will last longer.
How to do it ?
Under Service Tools -> Communications -> Join Details
Select “Don’t Attempt to Join” so that device would not look for networks
This would stop the device from looking for a network & hence save some battery usage
