Troubleshooting a passing control valve with DVC
HI
Is there a procedure or steps to follow, to troubleshoot a passing control valve, to know the root cause without removing and dismantling the valve.
The valve(s) is FISHER make with DVC on.
Thank you
  • Valve Signature is one of the possibility to provide areas of concerns for passing control valve, when mounted with DVC with Advance diagnostics tier. Off line test without taking valve out of line can provide good indication of seating areas of trim, shut off requirement, possible plugged part between seating area etc. This will assist to root cause the exact problem. The diagnostics results (Valve Signature) may require sharp eye from Emerson certified service engineer to provide path forward. If you could please advise your location, we could have local Emerson team to contact you.
    Thanks and regards
