i have fisher control valve with data following:
actuator: serial no:16962944, type:667,size:45,bench set:6-30,travel:2 in,oper. range:6-30.
body:serial no.:16973759,type:EWT,size:6X4,rating:CL600/1500 psi CWP,Plug:416 SST/Whisper,body:WCC.STL,port size:4 3/8 IN,stem :316 SST,seat:416 PTFE
i want spare parts list for this valve.
Hashem,
Fisher control valves are an engineered solution designed for the specific process application they are installed in. Components that are commonly found on a spare parts list for a control valve include the packing materials, gasket set, plug-stem assembly, plug seal ring, seat ring, and cage. Depending on the process and environment, the valve body components, actuator, positioner, and other accessories may also be candidates for routine inspection/maintenance. It's best to work with your local Fisher sales office to review your application and make specific repair recommendations based on your individual needs. They should be able to provide a recommended spare parts list and service options for you upon reviewing the application. The link below has contact information for all of Emerson's local sales offices:
http://www2.emersonprocess.com/en-us/brands/fisher/contacts/pages/contacts.aspx
Regards, Jake
