Problem:
After struggling with reliability and safety issues due to repeated severe packing leaks with a competitor’s sever service construction, a large Power generation facility in the Midwest decided it was time to address the problem with a better technology. After being installed in 2004, the control valves had always been a risk with over 10 severe packing leaks that create hazardous working conditions and reduce the operating efficiencies of the facility. After a catastrophic plug/stem failure in 2015, the facility called upon Emerson Process Management for a Fisher control valve to address this critical application.
Solution:
With the severe process conditions presented by the high pressure superheated steam, it was critical that a control valve capable of noise reduction and vibration resistance be specified for this application. With all of the challenges addressed, the customer installed a pair of NPS 1.5” Fisher HPS globe valves into this application, with one being expedited through the Quick Ship program in response to another unplanned outage due to a failure of the competitor’s valve.
Results:
Once installed, the Fisher HPS globe valves with Whisper-III trim technology and remote mounted DVC 6200 have provide reliable control of the steam to ensure proper operation of the facilities soot blowers.
If you would like to know find out more about this application and Fisher solution, please comment below, or contact your Emerson Local Business Partner for direct application support.
2703.Sootblower Valve Application-JWR.pdf
