I have a new Flexim Ultrasonic flow meter that shows flow and other variables (sounds speed, etc.) locally, but in AMS and DeltaV (14.3.1) shows "bad sensor failure". Only temperature and signal strength show "Good". All the other variables, including standard volumetric flow rate, show "bad". Any idea what I am doing wrong? The DD I downloaded from the Emerson website would not load, however the one that was on the media supplied by Flexim loaded okay and I was able to commission the device. I can configure an AI for temperature and it works fine, but flow rate still shows "bad sensor failure". Any thoughts?
In reply to John Rezabek:
