I recently went from ME 9.5 to ME 9.8 after doing a clean uninstall of 9.5 (uninstalled everything related to PME). Everything worked just fine, I was able to customize the toolbars, etc.
We then found out 9.8 is not officially supported by Windows 11 so we decided to then make the longer jump to 10.0 since I'm sure at some point we'll get there. I uninstalled 9.8 PAC ME only, then installed 10.0. Everything appears to work fine except that any custom settings are not saved and I get a notification popping up that says "Environment Was Not Saved" when I open/close out a project or close PAC ME.
I've tried Run as Administrator and various other things but still get the same message. I'm sure it has something to do with not being able to save the settings somewhere. Seems I've run into this a couple years back with testing 9.7 but it's been a while and don't remember if I found a fix.
Anyone else seen this?
Thanks!Bill
