OPC Mirror takes about 6 hours to finish initialization after OPC Server is restarted in the plant.
One of the packages which is connected to this OPC server is currently out of service so not communicating with this OPC server so the data coming from only one of the 19 pipes is not healthy.
Auto enable is disabled for all the pipes for this server and this is a simplex OPC server, DeltaV Version is 11.3.1.
Is it normal for the OPC mirror to take this much time to initialize and establish the communication after restart of the server if one of the pipes has bad data coming.
If yes, is there a way out to reduce this initialization time and establish the communication quickly after the server re start.
Will appreciate Any insight and help on this if someone had this same issue?
BRDS
In reply to dikshitsh:
In reply to LaurentB:
