Hello,
I have a problem with Events view. No events or alarms are showing in history view window. What could be the possible reasons? Help me to figure out.
In reply to Mark Millar:
Yes it is selected to advanced.
In reply to ATK:
In reply to LaurentB:
I think there is no problem with the login. If you kindly explain about the login it will cleared the doubt if any.
For login, the question is , are you sure you are are logged in the deltav Log on with a deltav user account ? But Iagree , i think this is not you're issue.
It seems you are well connected to an active dataset of ejournal
Are you sure that the areas where the module are located are assigned to Alarms and Events of the station ?
Does your issue occurs on all module , all stations ?
From history view, if you create directly new event chart ( File/New/Event) do you get event ?
