Hello, I am a retired automation engineer and now working as volunteer at Scalda Technical school on a Emerson DeltaV system version 13.3.1 Build 6309.
This is a new system, the old system version 7.4 Build 4393 will be replaced. I managed to program all IO in the system but I can not migrate the old
Fieldbus Library, this is essential for the system to work. I used the migrate tool to upgrade the old library to 13.3.1 but when I select Import in the explorer, the library
does nor show up in the tree and is not placed elsewhere. I have a registered system and it looks like the Library map is not available for me.
I imported other objects all IO with the same procedure and that worked fine, and is visible in the explorer.
If you know a way to fix this , all help is welcome, thank you.
In reply to Lun.Raznik:
In reply to wjdreves:
