Is there any reason to expect reduced controller loading when an EIOC replaces a VIM?
Since the EIOC is reported to function (in some respects) as controller, is any processing power shifted to the EIOC and could we expected reduced loading on controllers?
In reply to Andre Dicaire:
Hi to everybody, I'm a newbie inside this forum, and I would like to have your support in relation to VIM Card and EIOC Card.
I have an existing Delta V system with a lot of VIM card, it will be foreseen a system expansion with external TCP/IP equipment to be managed too. Emerson offer EIOC Card with DV system, instead VIM Card.
Customer is requiring to collect the expansion and existing into a central control room as per architecture (see picture attached).
Question: Could EIOC and VIM Card co-existing on the same network ? As I read the configuration Machine shall not be more used with EIOC it's correct ? Shall I insert some additional hardware and/or software for co-existing VIM and EIOC ?
Thank you
In reply to Piero Ranieri:
