Limitation of max samples values in Excel Add-in
I am using Deltav 12.3 excel addin to get process history data to excel. But I found out that there is limitation in "RAW data function" in maximum samples of 65536. Is possible to change this limitation somehow or is there any other possibility how to get bigger amount of process history data to excel?
Thank you
  • Which version of excel are you using ?
    Excel 2003 and below is limited to 65.536 (= 2^16)
    An alternative to excel to collect data in DeltaV Historian is to use the shell commande DVCHDUMP ( Open a prompt command and type DVCHDUMP /? to understand syntax)
  • In reply to LaurentB:
    I am using excel 2010 where I can have more then 1 milion rows
  • In reply to Dragonfly:
    You're right , I found this information "For now, DeltaV Reporter has a limitation of 65,536 rows regardless of Excel version"
    SO you have work around if you really need more.
    Suggestions :
    - Use DCVCHDUMP ( less user friendly but very powerfull) ( you can build macro in excel to export the command and import the result
    - split your addin queries into severall shorter period or increase the sample time to reduce line number. At the end working with much more 65536 lines in excel will be not very efficient also , Excel will be very slow to manipulate these data
    Thank you. This tool looks very good. Is there any limitation of using it? I wouldn't disturb the historian process...
    I already used it to get Giga bytes of data. That requires CPU , memory and drive ressources, but depending of the server , it could be done directly on appstation, but if the amount data is very large , it could be slow down. Depending of the other roles of this station, it could be better to export/import data set to a simulate plateform to extract more then 10G byte of data.
    Is there possibility to get interpolated values similar to the command Interpolated values in the Excel Add-in?
    Is it ADJUSTED VALUES or RESAMPLED VALUES?
    When I need RAW values a write command DVCHDUMP raw. But what should I write if I need this resampled values? I don't see it anywhere in the help.
    As I said DVCHDUMP is very powerful but less user friendly ...
    But Yes you can extract data with all options you need.
    To find Help on this command just type DVCHDUMP
    Below the paramters yo have to use
    Items that can be dumped:
    HISTORY DATA SOURCES
    HISTORY TAGS NAMES
    [<tag criteria> [<data source criteria>]]
    HISTORY CONFIGURATION
    RAW HISTORY SAMPLES
    [<datasource>] <tag> [<start time> [<end time> [<startBound> [<endBound>]]]]
    [/INFO=4] [/EQUAL]
    HISTORY STATUS CHANGE SUMMARY
    [/MAX=<num>]
    HOLES IN HISTORY RECORD
    [<datasource>] <tag criteria> [<start time> [<end time> [<startBound> [<endBound>]]]]
    [/MAX=<num>] [/INFO=2] [/ITF]
    LONGEST INTERVALS IN HISTORY RECORD
    [<datasource>] <tag> [<start time> [<end time> [<list length>]]]
    [/MAX=<num>] [/ITF]
    SHORTEST INTERVALS IN HISTORY RECORD
    [/MAX=<num>] [/ITF]
    OUT OF TIME SEQUENCE SAMPLES
    [<datasource>] <tag criteria> [<start time> [<end time>]]
    [/MAX=<num>] [/ITF] [/INFO=1] [/EQUAL]
    PROCESSED AGGREGATE VALUES
    [<datasource>] <tag> [<aggregates+fields> [<start time> [<end time> [<interval>]]]] [/AI]
    RESAMPLED VALUES
    [<datasource>] <tag> [<start time> [<end time> [<resampleFactor> [<startBound> [<endBound>]]]]]
    [/INFO=4] [/EQUAL] [/ALGO=1]
    GRAPH PLOTTING POINTS
    [<datasource>] <tag> [<start time> [<end time> [<interval> [Y-axisRange]]]]
    INCREASING MAXSAMPLES
    [<datasource>] <tag> [<start time> [<end time>]]
    [/MIN=<num>] [/MAX=<num>] [/INCR=<num>] [/SLEEP=<num>] [/INFO=1]
    ADJUSTED VALUES
    [<datasource>] <tag> [<start time> [<end time> [<resample interval> [<tolerance>]]]]
    ALGORITHM TEST FROM FILE
    [<resample interval> [<tolerance>]] [/ALGO={0|1}]inter
     (Raw samples expected as standard input)
    '/NODE=<serverName>' can be added to send DvCHDump requests to a DvCH on another node.
    '/PRI=< HIGH | ABOVE | NORMAL | BELOW | LOW>' will set process base priority.
    Data sources are like:  DeltaV=<nodeName>
    Tag and data source match critera may use leading and/or trailing '*' characters
    to indicate a wildcard match of 0 or more characters.
    Start/end times may be absolute or relative.  Always UTC based:
     Absolute:  example:  2004/03/19 17:53:00
        Note: usually have to put date and time absolute times in double quotes so
              command window shell will treat it as a single command line parameter.
     Relative:  (follows OPC HDA specs)
        <base>[<offset>[<offset>[<offset>[...]]]]
     where <base> is any of:
        NOW SECOND MINUTE HOUR DAY WEEK MONTH YEAR
     and an <offset> is
        <inc>S <inc>M <inc>H <inc>D <inc>W <inc>MO <inc>Y
    meaning:  sec    min    hour   day    week   month   year
     and
        <inc> is:  +|-<number>
     Examples:
       NOW  NOW-1H-30M  DAY+1H WEEK-3D+8H ...
    <startBound> and <endBound> boundary type specifications are single letter abbreviations:
     N  - None
     O  - next raw sample Outside specified time span
     I  - Interpolated value at specified start/end time
    <aggregates+fields> is a comma delimited list of aggregate ids; so far, one or more of:
              %AVAIL,%GOOD,COUNT,FIRST,INTERPOLATED,LAST,MAX,MIN,AVE
              %NOTBAD,%NOTLIMITED,RANGE,STDEV,TOTAL,RAW_AVE
     Specifying the aggregate name produces just the "value" of the processed sample.  To
     also see additional information for the sample, one or more of the following
     extra field ids may be appended:
              +Time         - includes the timestamp for the aggregate.
              +DvStatus     - includes the composite DeltaV (Ff) status for the aggregate.
              +DStatus      - includes the composite DeltaV (Ff) status decoded as a string.
              +ArcStatus    - includes the (numeric) DvCH archive status for the aggregate.
              +AString      - includes the DvCH archive status bits decoded as a string.
              +Year         - includes the year and month from the timestamp for the aggregate.
              +Frac         - includes the fractional second from the timestamp for the aggregate.
     Aggregates and field ids can be abbreviated to the point ambiguity.  Examples:
        COUNT,%GOOD  would return values for these two aggregates
        MAX+T,MIN+T  would return the min's and max's, along with when they occurred
        I+T+D+A      would return the INTERPOLATED aggregate, plus time, and both statuses
    <interval> is the resample interval (time span) for reading processed values.  Examples:
        30S           = 30 seconds
        2H30M         = 2 hours and 30 minutes
        5D12H         = 5 days and 12 hours
        200T          = 200 milliseconds (Thousandths)
    Most commands accept '/LT' which causes all timestamps displayed to be converted to local time.
    Some commands accept '/MAX=<num>' which sets the 'maxSamples' parameter on readRaw calls.
    Some commands accept '/AI' show invalid content from samples with AggregateValueInvalid status.
    Some commands accept '/ITF' which ingores the 'data trucated' flag on readRaw calls.
    Some commands accept '/INFO=1' which includes addtional details.
    Some commands accept '/EQUAL' to indicate that equal timestamps should be flaged as a problem.
    Archive status bit abbreviations used:
      AI - AggregateValueInvalid
      CR - HistoryDataUnreadable
      DU - HistoryDataUnavailable
      NC - HistoryCollectionNotConfigured
      SD - HistorianOrScannerShutdown
