Hello,
I have a command driven equipment module that is used to unload fertilizer into tanker trucks. Previously the three named sets were 'OFF', 'load from tank A', load from tank B'. We are now constructing 'tank C' so I require a 4th command, which Delta V populated in control studio after adding it to the named set associated with it. My issue now is that my faceplate no longer has any of the command SP buttons after adding the 4th command. Digging into the script I see comments for code written for instances of 2-state device control and 3-state device control.
How complex is it to create a custom faceplate identical to the one I am using, but with 4 commands? My only other option currently is to create a new EM using the EDC functionality which gives you up to 6 commands, allowing me to utilize the associated faceplate and detail for it. (This EM was created before we upgraded to V13 or had access to the enhanced function blocks).
Thanks
In reply to Matt Stoner:
In reply to Cogan Stewart:
