FireWall
I want to connect to opc server via firewall. But I could not configure the firewall. What is the default username and password for Emerson Smart Firewall. Please help me! How to set up a firewall.
  • KBA AK-1500-0032 has all necessary information about the Emerson Smart Firewall.
    If you forgot the firewall's administrative password you will need to reset it following the procedure also mentioned in this KBA which will require physical access to the device using a serial cable.
    For a running firewall (or before putting the device back in operation), the default credentials should have already been changed from its default, if not please do so at your next opportunity.
