ASA Firewalls
I am setting up some ASA firewalls as part of a DeltaV install. Is there any advice out then on config of these. Gotchas, advice etc. Appreciate if anybody can offer advice.
  • They are pretty straight forward, especially the later models when using the ASDM interface to set them up. High Availability can be a pain, trying to get the correct license from cisco and then uploading to the ADA has been my biggest issue.
    You just using this to protect the plant LAN, right?
  • In reply to AdrianOffield:
    Adrain
    Yes they are the outward facing facing firewalls from the PCS tied directly to the Plant Lan firewalls provided by IT. I have to deal with them on this job as they fall under my scope. Most jobs in the past have had an stand alone PCS and then they tied them to the Plant long after I had left. I have kept up to date on the guidelines but have not had to deal with the specific configuration of the Automation firewalls before.
