Rename areas
Hello to all
I need to rename some areas of our system, I have the following doubts:
What kind of download must be done after renaming the area?
What is the total download of Proplus?
Best regards
Felix
  • Hello Felix.
    Without answers, have you tested the "try&error" method by your own already?
    Was it successful? Which downloads were necessary?
    brg Stefan
    Stefan Müllner
    Senior Plant Engineer - Automation & Systems
    METADYNEA AUSTRIA GmbH
  • In reply to Stefan Muellner:
    Hello stefan,
    After renaming the area perform SetupData to the ProPlus station.
    and later to the rest of the stations
    The above worked on DV v14.3.LTS
    Best regards
    Felix
  • In reply to Felix:
    In general items related to hierarchy such as plant areas, unit modules (not used for batch), assigned plant areas on a workstation, moving a module, etc just need a changed setup data download to the appropriate workstations once changes have been made. No guarantees that covers everything, but will cover the most common scenarios.
