Soft AO Block
I want to use the AO block OUT parameter to a CALC block for calculation and then onward propagation to a Profibus DP. Problem is without a proper IO channel assignment AO block shows Error (that then shows up in the Detail face plate). I have used MASKING but still get error in one way or the other in the module. Module is part of library with interlocks and other things so don't want to remove AO block altogether. I was hoping a a kind of PSEUDO/ SOFT/ DUMMY AO block that ignores the Output Channel failure.
Any thoughts?
