Version Control and Audit Trail
HI
How we enable the Version Control and Audit Trail  for deltav 11.3.1 it don't appear in Database administrator
  • You need to run setupsql.exe to install SQL Standard. After that the option should show up in Database Administrator. Note that the ProPlus has to be running a server OS.
    Audit Trail is part of AMS (Full Version)
  • In reply to Lun.Raznik:
    VCAT is a DeltaV option, that includes Version control and Audit trail, for DeltaV configuration database.
    AMS Device Manager Audit Trail is a separate software. This Audit Trail tracks changes and events related to AMD Device Manager smart devices.
    Thanks for answer, what the issue if the Proplus change to the server OS, the SQL run only on server workstation so if run in proplus what will be different and what the effect on the proplus
