DeltaV Excel Runtime Data Add-in Not working.
DeltaV, version 13.3.1, Build 6309
MS Excel 2016, 32-Bit
Problem: After following the steps in the Wizard for a “Configure Read Function” on a single, valid tag the cell reports “#NAME” and the immediate cell to the left displays the Excel Function Warning (yellow triangle, exclamation point), with message “The formula contains unrecognized text”, even though the Wizard generated that formula.
The workstation is fully licensed and the DeltaV Continuous Historian Add-in works fine.  I’ve tested it on three different workstation with the same results.
I’ve already checked for an issue with Excel configured to require Trusted Signatures for Add-ins and that is apparently not the problem.
Any help is greatly appreciated.
Thanks.
CH
