Hi all,
Any idea on below for PHV reporting alarm when alarm limits was not reach?
It is pulling vacuum at 375 SP and logic have a transition to see if PV is below hi limit SP of 375 (which was obviously reached) based on trends.
However, the moment alarms are enabled at the end before reaching vacuum, this alarm shows up.
Appreciate your help. Thank you!
In reply to James Beall:
