I'm very green and this is my first post, but I'm looking for guidance on the most efficient way to pick between two analog input blocks for use in a PID. The trigger for which AI signal to use depends on our tank configuration. The tank configuration is captured currently as an Operation recipe parameter. I thought to use an ISEL block then write to the OP_SELECT parameter indicating which AI to use depending on the recipe parameter. I appreciate your feedback.
In reply to dmitriy sagadiev:
In reply to Erik Berry-Sellers:
