missing all deltav user in the log in flex lock after restarting the system (DeltaV 13.3.1)
hi
i have problem with deltav user after restarting the system .all the user missing after restarting the system in the DeltaV 13.3.1. what should i do? i just upgraded the system to 13.3.1.
regards.
  • Please supply more details.
    You 'just' upgraded to 13.3.1, what stage of upgrading you are in?
    Did you do the workstation configuration utility, did you import the migrated export, ... ?
    Maybe relevant: from which version did you upgrade?
  • In reply to Maarten van der Waal:
    hi
    i have done the upgrade from 11.3.1 to 13.3.1 . i have done all the migration path and the workstation configuration several time . so when i start the operator workstation all the user could not be displayed in the flexlock and workstation did not work. after downloading the workstation this matter exist. i also reconfigured the workstation but no result.please let me know how to resolve this issue.
    regards.
  • In reply to samy:
    I had a similar problem when loading configuration into a new (virtual) machine. It appeared the Windows user was not a member in the imported DeltaV configuration. So by using a different (Windows) user, known in the imported configuration, I was able to to a download after the workstation configuration and then all users were seen.
  • In reply to samy:
    You should log a call on this issue with Guardian/Global Support Center to get the support needed for your migration.
