For option selection in a graphic a ComboBox is used. This Combox is filled with selectable Items using a script.Depending on the number of items in the ComboBox it is to be enabled or disabled.
The state in the process (DeltaV parameter) is to be used to enable or disable the ComboBox also.Now I cannot get the Enable Animation to work on the expression 'parameter AND ComboBox.Listcount.In the scripts the ComboBox.Listcount is working correctly. This is not the case in the Animation however.Using the parameter only is working good. The ComboBox.ListCount seems to result in a 0 (zero) always.
How can I get the number of Items in a ComboBox into an animation expression?
In reply to Matt Stoner:
In reply to Maarten van der Waal:
Where is the logic that is creating the selections of the combox? You would do your counting in that script and save it to the iFix Variable.
I did a quick test and the ListCount works during that script, you just need to save that value somewhere the graphic can reference:
Private Sub cboTest_DropButtonClick()On Error GoTo ErrHandler Dim i, z As Integer z = InputBox("Enter number of choices") cboTest.Clear For i = 1 To z cboTest.AddItem "Entry " & i Next i MsgBox cboTest.ListCountExit SubErrHandler: frsHandleErrorEnd Sub
