I can not seem to get this modifier to work. Whenever I switch to the run time, I get the error that the parameter is not configured. I know it's not. Don't worry about why. I want to use the modifier to suppress the configuration error dialog. I have done the following:
object is "Datalink1". Opening the Animations dialogue I set the source as "DVSYS.B-2614/IT1/PV_D.F_CV[_NOT_CONFIG_OK_]".
The expression parses fine as if i had no modifier, so I trust the syntax is correct. I don't know what is wrong, but I still get the error. The HELP topic doesn't show an example, just says to add the modifier to the datalink. Doesn't say where, but I've seen several examples given that show the same method as I'm using. Any help would be greatly appreciated. Thanks!
In reply to Matt Stoner:
In reply to MPhatale:
In reply to TreyB:
To add an image in your original post, use the highlighted "Image" icon in the tool bar as shown here:
To add an image in a REPLY, choose: USE RICH FORMATTING in the bottom right of the reply window and the tool bar will then appear.
Then, browse for any image on your phone, computer, etc and UPLOAD then INSERt. Once the image is placed, you can also right click on the image to format, resize, etc.
Best Regards,
