Our Proplus is looking at a NTP server on the network, all other nodes look to the ProPlus to get the time. Some of them look to the Primary NIC IP, some of them look to the Secondary NIC IP.
What determines this IP address. I can't see anything in setup that does this.
Thanks
In reply to Abhinav Thakur:
No, I want to know WHAT determines the IP Address in diagnostics. When I look at a node in diagnostics (not the ProPlus) it displays the NTP Server machine (ProPlus) and also the Primary or Seconday network IP Address. What determines the primary or secondary. The only thing in the Physical Network properties is the ProPlus no IP.
In reply to Eric Stephens:
