Is there a module parameter that will give you the area the module is assigned to? I can't seem to find it in any documentation. For example, the DESC parameter can give you the tag name via DVSYS.@MOD@/DESC.A_TAG. Is there one for area?
I was looking into having a faceplate that will display different items depending on plant area.
In reply to István Orbán:
In reply to cslattery:
