I'm looking for input on the pros and cons of using unmanaged vs. managed switches in the VIM network. I have a VIM2 setup as a master and communication is ModbusTCP for all devices connected. For this application I currently have one switchconnected to the application station, VIM2, and a SignalFire wireless Gateway. I am looking to bring in two more devices to this VIM2 for which I need a second switch; a 4B Watchdog SuperElite and (3)Rosemount 5708 solid scanners running through a Chiyu BF-430 converter. These two additional devices are located in close proximity to each other next to a fiber patch panel where I have several spare fibers that will give me a direct shot down to the VIM2. Question is, would it be better to have the second switch as unmanaged, managed, or does it matter?
Also has anyone used or used something similar to ANYBUS X-gateway with communication protocols ModbusTCP client/EthernetIP adapter? I would like to test VFDs in our instrumentation shop using Ethernet/IP on a VIM2 that is loaded with Modbus driver; and was thinking of exploring this option.
DV13.3
Thanks in advance
In reply to dave_marshall:
