Win 7 Pro SP1 (Virtualized inside Oracle VirtualBox)
Hardlock key is passed into the virtual machine and recognized by both Win7 Pro and DeltaV software.
Licensing Properties
It appears as if I have to assign/configure the license for DV Sim but when I rightclick on the workstation and select Assign License, the window that opens has nothing to choose. Same when I select Unassign a License. When I selected CHECK it says all is good. Downloading the workstation is successful.
Now..
when I select Ctlr1 and check license I get this error.. ERROR: This node cannot be downloaded as the ProfessionalPlus Station has a DeltaV Simulate license. Assign/Unassign license are empty as they were with the workstation.
Is my licensing configured right at this point or have I missed something? Do I need to create a different controller type for simulate? And I also cannot commission CTLR1(it does not show under Decommissioned Nodes), but I suspect that is currently due to the license fault, is this thought correct?
In reply to Nova5:
