Can we create aliases for EM's ?
We are following a class based structure for CM's,EM's and Phases,however we have gone through the EM testing(EM instances) with control modules without creating unit class and phases.
Now, for phase and unit configuration and follow class based structure need to assign these tested EMs.if i want to add the EM's class to the Unit, then i need to do the whole EM instance configuration and in dont want to change anything on tested items.Instead can we use Alias concept for EM's.Please correct me if i'm wrong.
Karthik.
Karma doesn't have any menu, you get serve what you deserve.
Yes EM's can use two different methods for aliasing:
In reply to Matt Stoner:
