What is the latest compatible DeltaV software revision with MD controller?
We want to upgrade our Deltav Control system from DV 8.3 .
Our controller are MD.
now I want to know  revision is the latest for upgrading without hardware change.
  • They can run on v12.3.1. There may be a rebate available to upgrade the hardware to MQ. You should check with your Emerson Services rep.
    I think they will also run in v13, but I have not checked that yet.
  • v11.3.1 is the last revision. you can run it on v12.3.1 with hotfix install (i don't remember the revision of the hotfix) but with a lot of problems.
  • According to the version 13.3 release notes, (NK-1500-0151), "MD controllers will continue to operate in v13.3systems. ALL controllers must show MD, MDPlus, MQ, MX, SDPlus, SQ, or SX in the controller property page before starting the upgrade."
  • The last version of DeltaV that will support the MD controller is version 13.3.1
