Serial data DST counting
Hello to all
According to delta V,we have to order a separate DST license for serial data.my question is that how can order correct license for serial data transfer.for example please advise me for ordering for serial data DST calculation including 500 digital and 300 analog signals.
thanks in Advance.
  • It depends on a couple things, to help with the answer could you answer a couple questions?
    1)What Version of DeltaV will this be implemented on?
    2) Does your plant use a "marshaling module" for serial data or do you reference each serial register directly to each individual module.
    Thanks!
  • In reply to Tyler Anderson:
    Dear tyler
    Firstly thanks for your attention.following is my answer
    1.its version 12.3 or earlier one
    2.i am not sure about that.colud you specify more in marshaling module.
  • In reply to Moji:
    Since V9.3 the serial license requirement has been removed so you shouldn't need an additional license.  I believe Tyler is referring to a landing module, where you address all the serial registers in this module, with control modules referencing the landing module. See below.
  • In reply to AdrianOffield:
    You mean that no need order any DST licesne for serial data in v9.3 and earlier one?
  • In reply to Moji:
    Beginning in version 12.3 of DeltaV, each serial dataset counts a 1 DST. The DST type is based on the type and direction of the dataset. Up to 100 integer or 50 floating point values can be in a single dataset. For instance, an entire input dataset of integer or floating point values counts as one AI DST.
    Prior to version 12.3, the DST count of serial datasets was based on how the data values were used. If all 50 values (or 100, again based on whether the values are floats or integers) from a single dataset are used in a single module (sometimes called a landing module), the dataset consumes 1 DST. If the 100 values are used in 100 different modules, the dataset would consume 100 DSTs.
    Moji, you didn't mention if the 500 digitals and 300 analogs were inputs or outputs, but lets assume they are inputs. Then also assuming they are in contiguous blocks of registers in the PLC, then in a V12.3 system, these values would require 5 DI and 3 AI DST's. Typically, I've seen digitals packed into integer words, so the 500 digitals would consume 32 integer values, which if in a contiguous block, would consume 1 AI DST.
  • In reply to Bruce Greenwald:
    Dear bruce thanks for your answer and have quaetions.
    as you said about dataset is a table for counting dataset regarding to type of serail data?
    further more the in your exapme how to calculate the 5DI dataset(DST) for 500digital signal?also you mentioned the input/output shall be effect to dataset regarding to serial type.am I true?
  • In reply to Moji:
    When you create your dataset, you'll select input or output:
    On the DeltaV tab, you'll select the signal type:
