Compile Error Update PopUps
Has anyone come into this problem before.
I'm attempting to run Update PopUps and Update Main displays from Operate Configure mode and i'm getting the popup message up "A compile error was detected in a script that was about to run. the script will not be started". has anyone seen this before?
  • Hi SYSKRIS, did you create or change any faceplate/detail faceplate? Maybe there is some dummy datasource. I think there is a tool on guardian that you can run and check all PIC files, including faceplates, details, templates...
