I have a DeltaV 11.3.1 Simulate System.
I want to allow the Operator to Save Charts created using Process History View.
When I log on to Operate directly through Flex-Lock and create a chart (using PCSD chart builder or through the application), the Save / Save As buttons are grayed out to an operator.
I have the function when I log in as an Administrator.
The Operator has the 'Control' key which is the same lock as the CHART_SAVE option is allocated in Field Security. He does not have windows Access.
I have done a full set-up data download.
Is there anything else I should check to enable chart saving?
