Can I add additional bends/corners to the wire diagram in control studio? to say bend it around a control that it would otherwise visually pass right under?
In reply to Alfred Pol:
My reply wasn't showing up when I responded via e-mail, so I'll try again using the website (view with fixed font to see ASCII art properly): You can sort-of add some. For instance: +---------+ | +----+ +---------+ | | +===============================+ | | | Something that needs avoiding | | | +===============================+ | | | | +---------+ +----------------+ + +---------+ Move the top block to the right until you get additional corners: +---------+ | +----+ +---------+ | | +===============================+ | | | | | Something that needs avoiding | | | | | +===============================+ | | +--------------------------------------------+ | | +---------+ +----------------+ + +---------+ Anchor the new wire segments, then move the top block back: +---------+ | +-------------------------------------------------+ +---------+ | | +===============================+ | | | | | Something that needs avoiding | | | | | +===============================+ | | +--------------------------------------------+ | | +---------+ +----------------+ + +---------+ Because they are anchored, you get to keep the new wire segments and your additional corners. There is not a way, to my knowledge, of adding additional segments beyond this.
In reply to SBPosey:
