Control Studio, dashes wires vs solid?
I can't find anything in the help system. is it a true/false indicator? I am only on offline edit mode using DVSimulate.
  • Nevermind... Found it.
    Feedback Wires — Wires that carry feedback signals in function block diagrams are displayed as dashed lines. Feedback wires are determined when a module is saved or when the function block execution order is set.
  • In reply to Nova5:
    Nova5,
    I would be careful using the term feedback because if the blocks don't execute in a certain order, the feedback signal could actually be solid and an input signal dashed.
    I would remember that a dashed line means that the data will be from the last scan of the module. Solid line means the data will be from the current scan of the module.
    Matt
  • In reply to Matt Stoner:
    That line came from the DeltaV built in help system.
  • Most commonly you would see dashed lines when a BKCAL_OUT parameter from a downstream function block is passed to the BKCAL_IN of an upstream function block. This "feedback" is an important part of obtaining bumpless transfer in cascaded control. If you have a dashed line going from an "upstream" function block to a "downstream function" based on the visual appearance in Control Studio, you may need to check your function block execution order for the reasons that Matt mentioned.
