Aspen CIMIO treats uncertain data as BAD so any uncertain data shows bad in DMC. If gathered with COLLECT the uncertain (or bad) data is replaced with -9999. Is there a way to force DeltaV OPC server to pass uncertain data as GOOD status (that's the desired behavior, use uncertain as good)? I know this could be done in the DeltaV module itself with custom code... On our Honeywell ESVTs (have tested this) uncertain data on the LCN shows as good when retrieved remotely from OPC. I don't recall if this is just the default behavior or a configuration switch but in any case would like to get the same behavior from DeltaV. Any experience with this?
In reply to gxmontes:
In reply to AdrianOffield:
In reply to Don Zentz:
