I am in the process of adding a new controller to my system, I am unable to see the Controller in the decommissioned nodes using Delta V explorer (Ver. 11.3), but I am able to see it using the Diagnostics software. Is this an issue as the controller firmware seams to be Ver. 12.3.?
If this is the case how can I set the firmware to Ver. 11.3 or be able to see the controller under the Delta V Explorer.
Thank you in advance.
In reply to GaryL:
Purnendu Saptarshi
Automation Engineer | Skellig Automation US LLC | Greater Boston Area, MA
