How to use Faceplate.
I am new with the system and learning the things with existing Implemented system.
Can anyone explain.How to use the faceplate.
The Faceplate Available for Example AI_FP.
I have to use this one.
Now there are parameters like DVSYS.@MOD@/DESC.A_ZONETAG
So if I provide the module name then this Faceplate bring all the information.Now where I have to specify all parameter.So My Faceplate works properly?
very much confused with face plates.
What is DVSYS.MODULE,How I assign it to the faceplate?
  • The faceplate is callled using a routine that indirects @MOD@ with the name of the module provided as an argument. Modules are configured with their faceplate type, so when you create an open faceplate link using the open faceplate routine, it uses the module name argument to determine which faceplate file to open and to perform replacement of @MOD@.
    To change the faceplate to use different parameters, change the parameter path after @MOD@.
    I can't recall the routine name, but the open faceplate expert in operate will allow you to assign this routine to the click event on the selected object.
