Dynamo Edition and Animation
Well I am learning from already build project.I just saw some custom build dynamos.
1).How I can edit them because there is no option for edit it.
2).How I can see what Animation is Available for that object.
It has only Script option nothing else.
  • Well,I found Dynamo Graphic in Pictures but I am not sure.Is there any way to know that where is actual object of Dynamo,I mean in which Picture?
  • In reply to obi1987:
    Well I just ungroup one dynamo to just learn,How things are working.It is bit confusing for me.
    Its a Valve Having TagName,Valve object and Valve Feedback Value.
    Here are the expression written
    For Module TagName
    DVSYS.MODULE/DESC.A_MODULETAG
    So I just find its drop object and assigned module.I try to find the parameter of module which is I think it should be DESC.etc?which contains the TagName but I didn't found anything?
    For Valve Animation
    DVSYS.MODULE/DC1/PV_D.F_CV
    Same confusion I have here because I am unable to find any parameter like that.
    And same for tag value
    DVSYS.MODULE/POSITION/PV.F_CV[_NOT_CONFIG_OK_]
