Can anyone tell me how to configure a valve module or faceplate so that after an alarmed state due to an interlock the valve requires a "reset" button to be pressed in the "device state" part of the faceplate. some of our valves have this and some don't.
I want to configure other valves to require a "reset" after an interlock has shut it, before it will open again, regardless of the PV.
I'm not sure whether I should be trying to change the faceplate diagram or make changes within the module or both.
thanks in advance
Lee.
