option bitstring
How to create a "option bitstring" parameter and how to configure different selections.
Thanks
  • You cannot create an Option Bitstring parameter for user defined data types.
    This parameter is used in FB definitions to provide configurable options that also come with dialogs to expose the bit meanings to the user. They are nothing more than an integer with bitwise manipulation.
    What I’d suggest is if you could describe what problem you are trying to solve and we might suggest another approach to get the desired outcome without the need for a user efined post ion bitstring parameter.
