Dear community members,
Does any of you use the Maintenance Agent software/tool? It is a tool to read statuses from Dell OpenManage via OPC DA directly into DeltaV. We encountered a strange issue with it, and I was wondering if this tool is used anywhere else, and if the issue is present there as well. The software is running on two application stations, through a scheduled task, which is set to run every 5 minutes. These application stations are also OPC servers. What we have noticed, is that every 5 minutes, exactly when the Maintenance Agent software is running, the OPC server doesn't send any value to the clients for 23 seconds, after which it recovers, and runs normally. It is like the Maintenance Agent freezes the OPC server. However, it looks like that the Maintenance Agent doesn't run longer than 1-2 seconds, so there is nothing that would explain the 23 seconds freeze. Sometimes the "5 minutes" are 10, sometimes 15, but always in the same time as the Maintenance Agent. When disabling the scheduled task, no issue can be seen with the OPC server.
Please share if you are using the Maintenance Agent, and you encounter this issue, or also if this issue is not present, that would mean that the root cause is somewhere else.
Thanks.
In reply to AdrianOffield:
In reply to Wengritzky Tibor:
In reply to Richard Dubois:
