I am attempting to use some of the dynamos in the PCSD HW 120 library. As an example, the workstation dynamo below.
When I drop it on a screen and double-click it to edit, I'm greeted by a VB error: "A compile error was detected in a script that was about to run...". While examining the VB code now on that screen, the compiler errored out on locating the sub or function "EditWorkStation." I was also unable to trace this out using the definition option. This error occurs with all of the dynamos from this set.
Am I missing a library or module somewhere?
Thanks,Dave
